Wannan tattunawa ta zama daɗaɗɗiya. Yi sabuwar tambaya idan ka na bukatar taimako.
Firefox automatically capitalizes
When trying to log in to other sites it automatically creates a capital at the beginning of my email address. Even after I reset my keyboard to small letters.
Yes, this auto-capitalization is annoying...
Is the problem that Firefox is autocompleting the email address from a previous capitalized entry, or is there a problem turning off upper case even if you are typing a completely new entry?
If you prefer the keyboard to always default to lower case, you can turn off auto-capitalization in the settings for your Android keyboard. For example, for the "Google keyboard" on the latest Android, it's under:
Settings > Language & Input
On the right-side of the default keyboard there is a button with 3 horizontal sliders. Tap that and uncheck the box for Auto-capitalization.
